Activity › Forums › Apple Final Cut Pro Legacy › Help with Cinema Tools and Final Cut digitizing. Shot super 16mm to end up in HD.
  • Help with Cinema Tools and Final Cut digitizing. Shot super 16mm to end up in HD.
    Posted by Jewey4 on June 19, 2006 at 7:49 pm
    Hello everyone.
    I’m trying to help a colleague out that has a project that was shot in super 16 and in telecine, transferred to DVCAM tapes. In the telecine process, they did not put a visual burn-in (not sure why he did that!)so it’s essential that Final Cut sees the key number & timecode info. His ultimate goal is to have the project finished in HD as well as on digibeta. Any advice in what needs to be done?
    I have the telecine files and using Final Cut 5. Do I have to import the telecine files first in Cinema Tools? I have never done this before.
    And I’m thinking since it was shot on 16 mm and finishing in HD, should I be cutting in 24fps?
    I’m also going to have to sync sound in Final Cut.
    When I create a new database in Cinema Tools, it prompts me to choose some settings- do these sound right…16mm 20, Video Frame Rate 24FPS, Sound TC rate 24fps, TK Speed 24????
    Do these settings matter or when I import the Flex files, will it automatically correct itself?
    After the import in Cinema Tools- do I export a “batch capture” in order to open that in Final Cut and digitize?
    I’m so lost so any help is much appreciated. Thanks so much in advance!
    Frank Nolan replied 20 years, 3 months ago 2 Members · 1 Reply
