Activity Forums Blackmagic Design HELP with Capture PLS. PproCS3 and BMD Decklink HD
  • HELP with Capture PLS. PproCS3 and BMD Decklink HD
    Posted by Honzak on October 2, 2007 at 6:34 pm
    Hi anybody,
    pls. help me with problem by the capturing from DVW 500P using SDI and 422 controlling. Remote control is running OK, just Capture window is all time gray, no preview, no picture.
    Premiere Pro CS3, build 347, drivers BMD version 6.4, Windows XP all updates, SP2, 2GB RAM, 3,4 GHz INTEL, ASUS board. The same situation with BlackMagic Deck Control. Thank you very much for any idea, any help. Honzak
  • Is this a new install of CS3 and HD card? Or was this system working and quit with new drivers? It sounds like the ASUS BIOS is not seeing the decklink card correctly.
