Activity Forums VEGAS Pro Help with Blu-Ray rendering, etc…
  • Help with Blu-Ray rendering, etc…
    Posted by Dan Katula on August 29, 2008 at 3:31 pm
    Hello,
    I’m having an issue with burning Blu-Ray DVDs an effecient way.
    Whenever I save a Blu-Ray file (i.e. Blu Ray 1920×1080 24p M2V) in Vegas and try to use it in DVD architect to author a Blu-Ray DVD, DVD architect has to re-render the entire file. For a typical wedding video that I’m doing that’s about 1 1/2 hours of video which takes nearly 24 hours to re-render (even on my quad core pc). Kind of ridiculous when I already rendered the file to be for Blu-Ray in Vegas using any of the Blu-Ray Video Stream presets under the Mpeg 2 (M2ts, M2V, etc…setting)
    Any help would be greatly appreciated, as I would love to figure out how to speed up my workflow.
    Thank You.
    Dan Katula
    Envision Entertainment
    Dan Katula replied 18 years ago 2 Members · 2 Replies
  • John Rofrano
    August 31, 2008 at 1:02 pm
    Dan, you need to set your Blu-ray disc up in DVD Architect to match your footage. Then it won’t re-render anything. This includes matching the resolution and bitrate of the project. Go into your DVD Architect project properties (Alt+Enter) and check that the resolution is 1920×1080 and the bitrate is 25Mbps. I’ll bet the bitrate is set to 18MBps which is the default. This is probably why it’s being re-rendered.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dan Katula
    August 31, 2008 at 4:08 pm
    Thanks.
    I can definitely see that being the problem. I know the resolution is set the same, but I doubt the bit rate is.
    I’ll let you know.
    Thank you.
