Activity Forums Adobe After Effects Help with aspect ratio and 16:9 final output to web
  • Help with aspect ratio and 16:9 final output to web
    Posted by Afc Dmc on January 30, 2007 at 3:44 pm
    Hi I have footage shot with a 16:9 anamorphic lens. In AE7 I just use the DV widescreen preset and adjust the pixel aspect correction, Everything is fine I render that way and output to DVD in full 16:9 mode!! But I need to make some wmv copies for the web, but when I render the video with the windows media output set at DV widescreen in AE7 the output is 4:3 stretch and I want to do a 16:9 widescreen wmv file!! what settings I need to be able to output a web wmv in full 16:9 Thanks!!!!
    Iancorey replied 19 years, 7 months ago 2 Members · 1 Reply
  • Iancorey
    January 30, 2007 at 5:20 pm
    In your output settings you need to stretch to the correct aspect ratio. Be sure to enable “High Quality Stretch” ;p
