Help with Andrew’s LightSaberV2: motionblur issues
Hi there,
I fear this is another crappy question wich is answered already, but trust me: I didn’t found it with the search. Maybe it’s because my english isn’t that good, I’m sorry for that!
Here’s my problem:
I used Andrew Kramers great LightSaberV2-Preset in the past and made a small clip, everything worked perfect.
Now I’m using it again, and I’m going crazy. I’m using it with AE CS3 (german version but with the english shortcut), on Vista x64.
First of all it does not work properly; it’s the “Missing: Saber_Controls” issue. I can use it anyway, with thick and thin it at “__FX_Saber__” manually.So I made a clip with it (with motionblur and obscuring). When I play it back with space, all goes well – but if I press 0 on numblock for RAM-Preview (or render it out), there’s some strange issue. The core goes blue sometimes (I fixed this with crushing the blacks with “curves”), and the really strange problem is this:
This still was made with the AE Frame Capture, here’s a manual token still (when it’s not RAM-previewed):
It seems like it cuts every motionblurred part. I tried using CC Force Motionblur, it does not worked. I did touch the shutter speed, but resetted it; motionblur is activated in the composition and the precomp (saber and obscure), the clips like the compositions. The red color are the sticks there were fighting with, just if you want to ask.
I don’t really understand this, and the problem is: I need these clips, it’s for a important production. Sure it would be possible to make these with 4 points etc, but I don’t really have the time anymore; because I in preproduction I thought I could use this preset, haha.I really hope there’s someone out there who can help me; thanks a lot!
Oh, and just have another look to this issue, with the blue cores (this is so ridicilous because there’s simply no color; if I make the saturation -100 it turns grey…?) and the not-working motionblur:
Without motionblur the sabers are ok, but there blue anyway. And I need those motionblurs :-/
Regards from Germany,
Lucas
