Activity Forums Apple Final Cut Pro Legacy Help with an FCP 5.1 crash
  • Help with an FCP 5.1 crash
    Posted by Christian Case on June 11, 2009 at 6:42 pm
    Would someone be so kind as to lend me their brain on this intermittent crash:
    Date/Time: 2009-06-08 14:41:06.502 -0700
    OS Version: 10.4.11 (Build 8S165)
    Report Version: 4
    Command: Final Cut Pro
    Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
    Parent: WindowServer [54]
    Version: 5.1.4 (5.1.4)
    Build Version: 2
    Project Name: FCPApp
    Source Version: 702211411
    PID: 306
    Thread: 9
    Exception: EXC_BAD_ACCESS (0x0001)
    Codes: KERN_PROTECTION_FAILURE (0x0002) at 0x00000088
    Thread 0:
    0 libSystem.B.dylib 0x9002bfc8 semaphore_wait_signal_trap + 8
    1 libSystem.B.dylib 0x90001810 pthread_mutex_lock + 472
    2 com.apple.QuickTime 0x9481aea8 QTMLGrabMutex + 72
    3 …ickTimeFireWireDV.component 0x9fe56400 FWMuxerBegin + 96
    4 …ple.CoreServices.CarbonCore 0x90bdf08c CallComponentFunctionCommon + 1196
    5 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    6 …ickTimeFireWireDV.component 0x9fe638a8 dyld_stub_CallComponentDispatch + -1612397112
    7 …ickTimeFireWireDV.component 0x9fe53c8c DVCodecDrawBand + 1228
    8 …ple.CoreServices.CarbonCore 0x90bdeff4 CallComponentFunctionCommon + 1044
    9 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    10 …ickTimeComponents.component 0x99f92408 ImageCodecDrawBand + 40
    11 …ickTimeComponents.component 0x99a8dbec BaseCodec_DecompressWorkFunction + 1324
    12 …ple.CoreServices.CarbonCore 0x90bf1e00 InvokeComponentMPWorkFunctionUPP + 24
    13 …ickTimeComponents.component 0x99a8beb0 BaseCodec_DecompressCallBack_Common + 2672
    14 …ickTimeComponents.component 0x99a8f288 Base_CDBandDecompress + 5592
    15 …ple.CoreServices.CarbonCore 0x90bdeff4 CallComponentFunctionCommon + 1044
    16 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    17 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    18 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    19 com.apple.QuickTime 0x948f2e28 ImageCodecBandDecompress + 40
    20 com.apple.FinalCutPro 0x0002bdcc FunnelDecompBandDecompress(FDStorageRec*, CodecDecompressParams*) + 728
    21 …ple.CoreServices.CarbonCore 0x90bdeff4 CallComponentFunctionCommon + 1044
    22 com.apple.FinalCutPro 0x0002bfd0 FunnelDecompDispatch(ComponentParameters*, char**) + 60
    23 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    24 com.apple.QuickTime 0x948f2e28 ImageCodecBandDecompress + 40
    25 com.apple.QuickTime 0x948e06a0 DoBandedDecompress + 14960
    26 com.apple.QuickTime 0x94aacb28 ICMAction_aligned + 1368
    27 com.apple.QuickTime 0x948dc9fc ICMDeviceLoop + 3564
    28 com.apple.QuickTime 0x948e4964 DecompressSequenceFrameWhen + 868
    29 com.apple.FinalCutPro 0x00423cbc VideoOutput::PostOutput(Output*, long long, BufferIndexEnum, bool, float) + 1576
    30 com.apple.FinalCutPro 0x00418248 FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 1652
    31 com.apple.FinalCutPro 0x00418d00 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 16
    32 …ple.CoreServices.CarbonCore 0x90bdf060 CallComponentFunctionCommon + 1152
    33 com.apple.FinalCutPro 0x00411e04 FCPMHDispatch(ComponentParameters*, char**) + 60
    34 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    35 …ickTimeComponents.component 0x99f96924 MediaIdle + 52
    36 …ickTimeComponents.component 0x999e60e8 doGenericIdle + 2248
    37 …ickTimeComponents.component 0x999e8ba8 GenericMoviesTask + 904
    38 …ple.CoreServices.CarbonCore 0x90bdf060 CallComponentFunctionCommon + 1152
    39 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    40 com.apple.FinalCutPro 0x00411e24 FCPMHDispatch(ComponentParameters*, char**) + 92
    41 …ple.CoreServices.CarbonCore 0x90bdeb7c CallComponent + 260
    42 com.apple.QuickTime 0x948d9834 MediaMoviesTask + 52
    43 com.apple.QuickTime 0x94857250 TaskMovie_priv + 3808
    44 com.apple.FinalCutPro 0x001c3144 DoMoviesTask(KGPlayerRec*) + 2716
    45 com.apple.FinalCutPro 0x001d6420 DisplayMovie(KGPlayerRec*) + 1880
    46 com.apple.FinalCutPro 0x001db284 pKGPlayerStop(KGPlayerRec*) + 1212
    47 com.apple.FinalCutPro 0x001d8230 pKGPlayerHandleDefaultMenu(KGPlayerRec*, long, unsigned long) + 1128
    48 com.apple.FinalCutPro 0x001d86b4 pKGPlayerHandleDefaultMenu(KGPlayerRec*, long, unsigned long) + 2284
    49 com.apple.FinalCutPro 0x001e1328 pKGClipDefaultMessage(long, long, KGDictInt*, KGDictInt*, long) + 1092
    50 …Pro.Plugins.Timeline Editor 0x06442030 DisposeMenuStrings() + 40288
    51 com.apple.FinalCutPro 0x002b8234 pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 2088
    I’ve truncated the message where the ellipses stop occuring in the report. I have swapped ram, cables, hard drives, video cards, fiber cards, and everything I can think of in an attempt to isolate and correct this problem, with no luck whatsoever.
    Any help would be met kudos, admiration, and more than likely fawning.
    Christian
    Christian Case replied 17 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
