Activity Forums VEGAS Pro Help with After Effects RGB+Alpha Settings for Vegas 20 Pro
  • Help with After Effects RGB+Alpha Settings for Vegas 20 Pro
    Posted by Daniel Collins on April 21, 2023 at 1:23 pm
    I have been using Vegas 16 pro and seamlessly importing After Effects RGB+Alpha Animation exports in my timelines for transparent titles, lower thirds, etc.
    I’m using the trial version of Vegas Pro 20, and these exports no longer work (Vegas won’t import them at all).
    Can anyone recommend export settings for After Effects 23 RGB+Alpha files that will allow me to use transparencies in Vegas pro 20?
    Many thanks in advance for your suggestion
    Aivis Zons replied 3 years, 4 months ago 2 Members · 1 Reply
  • Aivis Zons
    April 21, 2023 at 3:25 pm
    Have you enabled the QuickTime plugin in Vegas Pro?
    Options -> Preferences -> Deprecated Features -> Enable the QuickTime plugin
    If that didn’t fix it you can render your animations as .png sequences. Just make sure that the framerate is correct when importing in Vegas Pro.
