Activity Forums Apple Final Cut Pro Legacy Help! White frame at the end of hinted clip.
  • Help! White frame at the end of hinted clip.
    Posted by Chris Wiseman on February 6, 2006 at 3:48 pm
    I am running FCP 4.5 with QT 6.5.1 on a Dual 2.7 with 2gb of ram. My client needs two clips (a 30 and a 60s) with Sorenson 3 compression and hinted streaming. On my box, when I export with the hinted streaming, the export is an additional frame long, and the frame is white. This happens on both QT and FCP export. I tried the same export on my home machine running QT7 and did not have the same problem. I can trim the last frame off in QT but I am worried that it might have some sort of negative effect on the hinted streaming. Does anyone know of a workaround for this problem. Thanks!
    Chris Wiseman replied 20 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
