Activity Forums Adobe Premiere Pro HELP | Weird rendering Issue | Clips with any sort of FX Rendered Brighter
  • HELP | Weird rendering Issue | Clips with any sort of FX Rendered Brighter
    Posted by Joshua Casper on January 22, 2021 at 2:55 pm
    I am trying to render some projects I edited in Premiere Pro (the latest version). I use PP literally at least 5 days a week for work and this issue is a new one.
    When rendering the project, any clips that are above 100% speed are rendered brighter. Also, images are doing the same thing and wherever I have a fade transition. These are the only places I have any sort of effects on the video elements, so it seems to be related to that.
    I have tried rendering a few codecs outside of my normal .h264 (avi, wmv, .mov) and the issue persists.
    I have tried all options in terms of render engine in Media Encoder (CUDA, OpenCL, Mercury Only) and just rendering straight from PP and the issue persists.
    I have emptied PP cache and all drivers are up to date.
    I have an Alienware 17 R5, i.7, 16 GB RAM, GTX 1070 (8 GB)
    The main clips I am editing were recorded with OBS.
    Type: MPEG Movie
    File Size: 143.74 MB
    Image Size: 1920 x 1080
    Frame Rate: 30.00
    Source Audio Format: 48000 Hz – Compressed – Stereo
    Project Audio Format: 48000 Hz – 32 bit floating point – Stereo
    Pixel Aspect Ratio: 1.0
    Alpha: None
    Video Codec Type: MP4/MOV H.264 4:2:0 (Full Range)
    Joshua Casper replied 5 years, 7 months ago 1 Member · 0 Replies
  • 0 Replies
