Activity Forums Adobe Premiere Pro help w premiere 6.5
  • help w premiere 6.5
    Posted by davidmccann David mccann on June 24, 2005 at 12:08 am
    i am having issues with premiere 6.5. i am trying to run a 2 1/2 hour wedding to vhs. it is edited very lightly so there is not that much going on. for some reason i will get random dropout on the vhs tape. 1 time it was at 40 min the next time was at 36 min and the last time happened at around 50 min. this is driving me insane. i also have had to rerun because still pictures will conform to the size of the following pic before it dissolve into it. the pic will actually change size and shape right before the dissolve. when i replace the pic it sends the problem to the next pic. makes absolutely no sense to me. please help??
    Mike Velte replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mike Velte
    June 24, 2005 at 12:05 pm
    If by “droputs” you refer to dropped frames, this is the bane of exporting to tape. It is you PC that is not playing every frame. Drefaging all drives and disabling all background apps, especially virus scans and network conections should help. Make sure you hard drives are less than 80% full. I dont do export to tape any longer. If a customer wants a VHS copy, I will dub from a DVD.
    The picture issue is wierd…what hardware capture card are you using? What size are your stills? And are you using a Premiere transition?
