Activity Forums Adobe Premiere Pro Help w/ importing avi clips, lacks video
  • Help w/ importing avi clips, lacks video
    Posted by Brent Persun on January 7, 2008 at 4:14 pm
    I created some AVI video clips to edit using a screen capture program called fraps on my laptop. I have Premiere on my desktop, so I put some of the clips on my jump drive and burned some to a DVD. When I try to import any of the clips into Premiere, only the audio shows up and there is an error message about not having the right codecs. Anybody know what the problem is?
    Mark Stuffman replied 18 years, 8 months ago 3 Members · 2 Replies
  • Mike Velte
    January 7, 2008 at 7:34 pm
    Installing Fraps on your desktop might help…depending on what the codec is.
  • Mark Stuffman
    January 9, 2008 at 11:30 pm
    Fraps is most likely storing the files using a codec that Premiere does not support (e.g. xvid). You can use gspot (https://gspot.headbands.com/) to see what codec is being used.
    If it is xvid, you need to convert it to something that Premiere will read. You can convert it to an mpeg1 files, using something like fxmpeg (https://fxmpegwriter.com/)
