Activity › Forums › AJA Video Systems › Help using 16:9 standard def SDI input and outputting DVD in 16:9 SD
  • Help using 16:9 standard def SDI input and outputting DVD in 16:9 SD
    Posted by Matthew Harover on August 16, 2009 at 11:55 pm
    I am using Sony DXC-D50WSH cameras which are 4:3/16:9 switchable. I know they are still standard def, but assumed a native 16:9 would lend itself better to a widescreen final product.
    Using the SDI output of a Panasonic AG-MX70 switcher, and maintaining a 16:9 signal from camera to Kona LHe Card SDI input, what is the best workflow to ensure 16:9 DVD? What format must I capture in?
    As a side note, I will also be broadcasting the output of the switcher in digital over coax, which adds yet another reason for the 16:9 setting of the camera.
    Thanks for any assistance possible.
    Matthew Harover replied 17 years, 1 month ago 4 Members · 5 Replies
  • Chris Tompkins
    August 17, 2009 at 11:25 am
    You can capture in many different formats and still maintain widescreen.
    Just go to easy setup and select an animorphic version of one of them. 8 bit uncompressed, 10 bit uncompressed, dv50, prores, all have widescreen ability.
    Just capture, edit, output widescreen – u’ll be fine.
    Chris Tompkins
    Video Atlanta
  • Matthew Harover
    August 17, 2009 at 7:57 pm
    What is the highest quality format for SD? Im guessing DVCpro 50? Also, any ideas on getting the same program (component output is available) recorded to BETA sp?
    Matthew Harover
  • Joey Burnham
    August 18, 2009 at 4:57 pm
    [Matthew Harover] “What is the highest quality format for SD?”
    Uncompressed 10 bit 4:2:2
  • Michael Sacci
    August 20, 2009 at 3:54 am
    Then ProRes 4:2:2, then DVCPro50 (which is 4:2:2 but 8 bit)
  • Matthew Harover
    August 20, 2009 at 4:13 am
    Thanks guys for the assistance!
    Matthew Harover
