Activity Forums Adobe After Effects Help, urgent! how to get this fx?
  • Help, urgent! how to get this fx?
    Posted by Marco on June 23, 2005 at 10:33 am
    I’ve searched here but no lunk – the thing is that I don’t know what to type in the search field to find the properly thread about this stuff.
    So, here’s the problem.
    I’ve to finish a work very soon and I need a fx like this:
    https://xplsv.tv/motion.php?id=152
    the fx I talking about is when the text UNTITLED turns into particles and then into that little circle.
    Now, it seems there’s a camera, a radial blur … but what about the paricles?!?
    I’ve tried the pixel polly fx, like ayato shows in his tutorial but is not right the same …
    Help mates!
    Steve Roberts replied 21 years, 3 months ago 4 Members · 11 Replies
  • 11 Replies
  • Marco
    June 23, 2005 at 11:41 am
    As usual it can always gets worste!
    now another problem: copying path in Illustrator CS2 and pasting it in After Effects and I get a double path. I’ve tried to delete the unwanted path but at the end of the lond and annoying work the single path it’s closed and there’s no way to open it! 🙁
  • Jimmy Zito
    June 23, 2005 at 1:35 pm
  • Marco
    June 23, 2005 at 3:04 pm
    thanks for your quick reply James, I’ve a hope now.
    btw, is there an alternative way? particle playground takes so longs time …
    maybe with trapcode particular?
  • Jimmy Zito
    June 23, 2005 at 3:43 pm
    Hmm, I don’t really have any experience with Trapcode Particular, but my guess is any effect that deals with particles is going to be heavy on the RAM consumption.
    Not that shatter is any faster, but there’s a tutorial on here called Introduction to Shatter or something like that. It has a technique that may also help you out.
    Hope that helps.
    Jim
  • Marco
    June 23, 2005 at 4:02 pm
    just found (it seems) a good alternative: Boris 2d Particles.
    It seems faster and ready to use.
  • Nathan
    June 24, 2005 at 1:19 am
    I am sorry if this is inappropriate, but I am trying the same thing but dont know how to get the particles to form another object. I figured it would be better to ask here than start a new thread. ANy ideas?
  • Marco
    June 24, 2005 at 10:13 am
    Nathan,
    as I wrote in my previous reply try Boris 2d Particles, it works like a charm –
  • Jimmy Zito
    June 24, 2005 at 3:43 pm
    Hey Nathan,
    Try this tutorial from the famous Ayato:
    https://www.ayatoweb.com/ae_tips_e/ae04_e.html#
    Also, do a search for “particle” on the cow. This has been discussed a few times before.
    Hope that helps,
    Jim
  • Nathan
    June 24, 2005 at 11:02 pm
    thanks I do have that I and I understand how to break the object apart, but how to form another escapes me, but I am going to search for “particles” now as recommended
  • Nathan
    June 25, 2005 at 4:06 pm
    I looked at that tutorial but I dont have final effects complete which the tut calls for. I searched for particles and found one topic but the answer was not really expanded upon. I’ll keep looking tho. 🙁
