Activity Forums Adobe After Effects Help, transparent text box
  • Help, transparent text box
    Posted by Adam J demientieff on April 13, 2005 at 6:49 am
    I’m new to AAE, have experience with photoshop. I would like to make a text box layer that is solid on the left and fades and becomes transparent to the right. Can I do this in AAE or should I create this in photoshop? Any suggestions?
    Adam
    Adam J demientieff replied 21 years, 5 months ago 3 Members · 3 Replies
  • John Dickinson
    April 13, 2005 at 7:26 am
    I’d start off by taking a look at Masks and Track mattes in the Help.
    John Dickinson
    Motionworks
    https://www.motionworks.com.au
  • Filip Vandueren
    April 13, 2005 at 10:23 am
    hi,
    2 possibilities:
    one way:
    create a solid layer, or use the graphic layer on which you want the effect.
    with the mask tool, draw a rectangle that falls mainly outside the solid, but overlaps where you want the gradient to be.
    like this:
    |             |  |   rectangular    |
    |     solid   |  |   mask           |
    Now give that mask a mode of subtract and a horizontal feather until it looks right. You can move the mask to the left or right to fine-tune, or use the mask-expansion parameter
    other way:
    add a transition -> linear wipe-effect
    settings:
    Transition Completion: 20%
    Wipe Angle: -90
  • Adam J demientieff
    April 14, 2005 at 8:59 am
    Wow, that was easy! Thanks for the help. I tried all night to figure that out on my own with no avail. I’m sure I will have more questions, thanks again.
