Activity Forums Adobe After Effects help to modify Dan Ebberts tute script
  • help to modify Dan Ebberts tute script
    Posted by Dflamholc on February 10, 2006 at 10:16 am
    hello, i’ve been playing around with mr Ebberts script below and been finding it very usefull! 🙂
    position+[0,0,(index-1)*this_comp.layer(“Null 1”).effect(“Slider Control”).param(“Slider”)]
    however, i would need to modify it to rotate each layer on it’s y axis, with a delay, as the slider reaches it’s end keyframe. i.e. as the layers spread in z-space they one farthest away starts turning 90 degrees on it’s y-axis and x frames/secs later the last layer finishes it’s turn on y-axis. hope i’m getting my point across here…
    hopefully someone knows exactly how to do this, thanks in advance! /d 🙂
    Mike Clasby replied 20 years, 7 months ago 2 Members · 1 Reply
  • Mike Clasby
    February 12, 2006 at 9:41 pm
    To get what you want, if I read your post correctly, we need to a two new sliders and modify some expressions.
    This is modified (a yikesmikes hack) from Dan
