Activity Forums VEGAS Pro Help! Sony Catalyst Browse wrecked my Vegas Pro (Error 0xc0000005)
  • Help! Sony Catalyst Browse wrecked my Vegas Pro (Error 0xc0000005)
    Posted by Sean Michael on December 10, 2020 at 7:56 pm
    Recently I installed Sony Catalyst Browse to stabilize my A7C footage. After installing the software, my copies of Vegas Pro WILL NOT OPEN. Vegas now crashes immediately when opening as the “initializing GPU-accelerated video processing” notice appears.
    The Problem: Unmanaged Exception (0xc0000005)
    I have tried uninstalling Catalyst Browse, reinstalling Vegas, and also installing the latest version of Vegas (18). Nothing works. Now Vegas will not open at all, regardless of the version.
    I’m at my wit’s end, on the verge of wiping the entire hard drive and starting fresh. But surely there is a fix. Any ideas? THANKS!
    Here are the full error messages:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 13.0 (Build 453) 64-bit
    Fault Module: C:\WINDOWS\SYSTEM32\OpenCL.dll
    Fault Address: 0x00007FFC4EAF2F56
    Fault Offset: 0x0000000000002F56
    Fault Process Details
    Process Path: C:\Program Files\Sony\Vegas Pro 13.0\vegas130.exe
    Process Version: Version 13.0 (Build 453) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2015-06-06 (Sat Jun 06) 00:53:04
    And here for Vegas 18
    Problem Description
    Application Name: VEGAS Pro
    Application Version: Version 18.0 (Build 373)
    Fault Module:
    Fault Address: 0x0000000007E6E7C0
    Fault Offset: 0x0000000007E6E7C0
    Process Path: C:\Program Files\VEGAS\VEGAS Pro 18.0\vegas180.exe
    Process Version: Version 18.0 (Build 373)
    Process Description: VEGAS Pro
    Process Image Date: 2020-10-27 (Tue Oct 27) 08:36:20
    Sean Michael replied 5 years, 8 months ago 6 Members · 7 Replies
  • 7 Replies
  • Rich Kutnick
    December 10, 2020 at 8:18 pm
    Try this link, which contains specific steps to follow in order to get rid of any traces of Vegas. Good Luck!
    https://www.moviestudiozen.com/doctor-zen-faq/602-how-to-clean-install-magix-vegas-pro-movie-studio
  • Setiawan Kartawidjaja
    December 10, 2020 at 9:51 pm
    hmm.. no issue to me after updating the Catalyst Browse.
    Try update the graphic driver & sound driver.
  • Steve Mann
    December 10, 2020 at 11:38 pm
    From a cmd prompt, run driverquery to see if Catalyst installed an incompatible driver.
  • Sean Michael
    December 14, 2020 at 7:11 pm
    Thanks to everyone for your replies. Still no luck, but I will be working on the problem more today. The reason I know it was Catalyst Browse that caused the problem is that I use 3 different laptops to edit video… On two of the laptops I installed Catalyst Browse, and Vegas immediately began crashing. Thankfully I realized what was happening before installing Catalyst Browse on my 3rd laptop! So I at least still have one that works for editing.
    I know it has something to do with OpenCL.dll and Vegas’ GPU-accelerated video processing. I would recommend VEGAS users avoid Catalyst Browse (at all costs!).
  • Steve Rhoden
    December 15, 2020 at 2:48 am
    Catalyst always install a openCL-CPU runtime package during its install. Try going into your “Programs and Features” folder and uninstall it and see.
  • Don Cady
    December 15, 2020 at 4:41 pm
    I had this same problem last Friday with Magix Movie Studio Pro Platinum and Catalyst Browse after an install. They both would crash upon opening. I found this link to fix the problem and it worked. I hope it helps.
    ://scs.custhelp.com/app/answers/detail/a_id/5206/~/catalyst-browse-crashes-on-launch
  • Sean Michael
    December 21, 2020 at 5:48 pm
    Wow! Thanks Don, this fix seems to have worked! I really appreciate you and everyone else for taking the time to reply to this thread.
    For future reference, if anyone else has this problem on Windows 10:
    Open your Start menu and click the Settings button. From the Settings menu, choose Apps & Features. Enter “OpenCL” in the box labeled Search this list. If “Intel SDK for OpenCL” appears in the search results, select and uninstall it
