Help solving Capturing Problem using FCP
Hi there,
I am digitizing some video footage into my FCP using use a Sony VX 2100 camera. Everything went smooth, but suddenly FCP seemed to have encountered a problem and my digitizing process would just not go through anymore. I only have about 15 mn of footage that I still need to get into FCP and I am not sure why it won’t let me do it. I’ve tried to use the Capture Now button on the Log and capture window, instead of Log Clip or Batch, because when I struggle with digitizing, The capture Now option is usually the best way to go. So I’ve tried that, but it still will only do 3 sec. and then it says there was a problem encountered. The tape I am digitizing is a regular Standard definition 60mn mini DV tape that I have shot using Canon GL2 camera. Could it be because FCp recognized a drop frame issue? If so, why didn’t I get a message saying so? Any suggestion anybody? I would be very appreciative.
Thank you so much for your help.
-Roshd Ghalleb-
Roshd Ghalleb
Mandrakfilm Corp.
Web: http://www.mandrakfilm.com
Email: Roshd@mandrakfilm.com
