Activity Forums Apple OS X HELP!! shared library error
  • HELP!! shared library error
    Posted by Mike Hennessey on September 29, 2005 at 3:15 pm
    HELP!!!
    I last night I did software up date (final cut 5.0.2 & security) and now I keep getting errors when I try to open applications.
    The error is a shared library error. It only happens on explorer and after effects. However when I try to open Final Cut and safari the icon in the toolbar bounces as normal then nothing happens. No error or arrow underneath. It
    Chucky3000 replied 20 years, 11 months ago 3 Members · 4 Replies
  • Mike Hennessey
    September 29, 2005 at 3:23 pm
    I meant to put in my original post that the up date stalled and froze up the computer. It was optimizing the disk and it stalled at 84%. I had to do a reboot and went in to do the software update again and that
  • Mike Hennessey
    September 29, 2005 at 3:33 pm
    Here is that error message
    Application launch failure
    The application
  • Tony! Hulette
    September 29, 2005 at 10:41 pm
    Hi Mike,
    It’s very important that you repair your startup drive and the permissions before (and after) any software updates (especially OS updates). You can try starting up off of your OS X installer disk and running Disk Utility to repair the drive and the permissions. This could fix your problem. If it doesn’t, or if you want to be safe, I’d choose to do an Archive and Install while started up off the Installer Disk. Be sure to select the options to save your files and applications (I forgot the exact wording). Once the old system is reinstalled. You’ll want to repair the permissions & drive again before running the Apple Software update to get to the current OS version. When it finishes updating, you’ll need to repair the permissions and drive one last time. If for some reason the update fails again, then I’d start looking at things like 3rd party memory (remove it and try again).
    Good Luck,
    Tony!
  • Chucky3000
    October 20, 2005 at 4:52 am
    The optimization can take a VERY VERY long time. I would only interupt the process if it stalled overnight or something. After my last update to 10.3.9, the whole install/optimization process took forever. Long enough for me to go downstairs and cook dinner. Better to wait an hour than to interrupt… Too late for you now, but other’s should beware!
