Activity Forums Adobe Audition Help. Session mutes some tracks, when using solo on others
  • Help. Session mutes some tracks, when using solo on others
    Posted by Xavier De champs on August 1, 2007 at 12:43 pm
    This problem has happened to me in lots of other projects. Usually there’s no way to fix it, as it follows the session-save-file.
    Problem is this:
    I play track A and B in a session. Then I fiddle with them both (effects and stuff). Then start listening to track B with the S (solo) button. Then I press the SOLO button OFF. Press play, and track A is STILL muted. To get the sound back on A, I need to push SOLO ON and OFF on track B. But this only works while the session is playing. As soon as I stop the playing, and start again, track A is muted again, no matter what SOLO-settings I have on track B.
    This problem seems to follow the session-file (it
    Xavier De champs replied 19 years, 1 month ago 2 Members · 3 Replies
  • Xavier De champs
    August 1, 2007 at 12:48 pm
    It was a user error. It
  • Willie Toth
    August 1, 2007 at 12:55 pm
    What version are you using? Sounds like it might be 2.0 … I have not seen this problem before so I am a bit clueless here … Have you tried to uninstall and reinstall? WILLIE
  • Xavier De champs
    August 2, 2007 at 2:21 pm
    As I stated in my second post on this subject, the problem is fixed.
    It was a user error (my fault). I didn
