Activity › Forums › Apple Final Cut Pro Legacy › Help Scaling Full HD to 720p
  • Help Scaling Full HD to 720p
    Posted by Declan Smith on November 7, 2009 at 1:32 am
    Hi
    I have raw footage that is Full HD (1920 x 1080) but is badly framed. The final project format is 1280 x 720. What I want to be able to do is drag the Full HD clip into the sequence and be able to effectively reframe it (as the source is in effect, a large size). When I drag the clip to the sequence, it first asks if I want to change the sequence (which I say No), then it displays in the canvas but it has been zoomed and cropped. I was expecting the wireframe to be larger than the image, allowing me to scale and reframe.
    Any ideas?
    Declan Smith
    https://www.madpanic.tv
    FCS3 / Combustion / Canon XL2
    Rafael Amador replied 16 years, 11 months ago 2 Members · 1 Reply
  • Rafael Amador
    November 7, 2009 at 3:54 am
    In the FC Preferences you must check that the clips don’t get resized when dropped to the sequence.
    Or just select the clips in the sequence and “Remove Attributes: Basic Motion”.
    rafael
    http://www.nagavideo.com
