Help! Rotoscoped figure showing up as white mask!
Hello, so I’m learning how to rotoscope a moving figure by applying its tracking data to a white solid. I’ve tracked the footage, applied the tracking data to the white solid, rotoscoped the figure I want removed from the footage on the hidden white solid layer, but can’t seem to ‘extract’ the rotoscoped figure from the footage. The mask is set to ‘Add,’ but when I reveal the white solid layer all I see is a white mask of the figure I rotoscoped.
I know the solution is very easy, but at this point I just can’t seem to figure it out. Thank you in advance for your response. I hope to hear back from you shortly.
