Activity › Forums › Adobe After Effects › Help replicating an effect
  • Help replicating an effect
    Posted by Ayotunde Ojo on June 20, 2022 at 12:44 pm
    I’m trying to replicate this glowy shadow look in after effects but I can’t seem to figure it out, Help please, Here’s the full animation if that helps https://vimeo.com/325581767
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Eric Santiago replied 4 years, 3 months ago 4 Members · 4 Replies
  • Graham Quince
    June 25, 2022 at 10:35 am
    I’d use a layer style, probably Drop Shadow set to screen
    If you right-click on the layer, in the menu, there’s an option for Layer Styles.
  • Eric Santiago
    June 27, 2022 at 12:45 pm
    Would like to know if there is a single button way but I’ve had to do that using masks.
    Most options dont give you the shape fall-off and at times I used Maya for trickier workflows e.g. animated stroke
  • Walter Soyka
    June 27, 2022 at 5:37 pm
    Instead of thinking of it as a glow effect that is driven by the shape/line animation, think about it as a separate blurred shape animation that occurs in a matted-off area defined by the main shape/line animation.
  • Eric Santiago
    June 27, 2022 at 5:59 pm
    Yep, I had some fun replicating the line animation.
    If anyone wants the AEP just holler.
