Activity Forums Apple Final Cut Pro Legacy Help! Reconnect Media Nightmare
  • Help! Reconnect Media Nightmare
    Posted by Tom Vickers on March 23, 2010 at 2:56 am
    Hi all-
    I’ve been working on a feature-lenght documentary project and have an hour long sequence in FCP. The media is stored on two external harddrives connected via FW800. Today when I try to open the project, it loads fine. I can see as the various sequences pop up that everything is connected. Then I get the prompt that some media files are offline – this is no problem, a few files have been deleted over the course of the project and it only shows a handful missing.
    When I hit continue, suddenly all the media in the timelines that resides on one of the external drives goes offline. If I try to reconnect, it says “unspecified path” and does not seem to even recognize the name of the clip or the parent clip.
    -I’ve tried older autosaved versions of the project. Same problem.
    -I’ve trashed the preferences. No luck.
    -I’ve run DiskWarrior on the problem drive. Still no luck.
    -I moved the media from the problem drive, reformatted, then moved it back. No luck.
    Furthermore, most of the time that I try to open the project, it gets hung up and frozen so I can’t even attempt to reconnect manually (which will take days given the number of clips).
    Does anyone have any suggestions? They would be much appreciated as I am pretty desperate.
    Chris Tompkins replied 16 years, 5 months ago 2 Members · 1 Reply
  • Chris Tompkins
    March 23, 2010 at 11:52 am
    Are you daisy chaining the drives? Do you have a deck also hooked up by firewire? Try hooking both drives up to separate ports?
    Chris Tompkins
    Video Atlanta
