Activity › Forums › Adobe After Effects Expressions › Help please. Property Group Hierarchy.
  • Help please. Property Group Hierarchy.
    Posted by Ahad Elshabeb on January 13, 2021 at 4:14 pm
    Hi
    I have a shape layer (named shape ) with 3 groups in it, named 1,2,3 respectively.
    Each group has 3 shapes ( not a puzzle I swear :p) named 1st, 2nd and 3rd, nested in a group ( named Group 1).
    I am trying to access the name of the shape layers (1, 2, 3) in their properties.
    Am I right in assuming the way propertyGroup behaves? (See picture uploaded)
    var groupIndex = thisProperty.propertyGroup(4).propertyIndex;
    var groupName = thisLayer(“Contents”)(groupIndex).name;
    Is it going 4 levels up to get the hierarchy ?
    In the image I am trying to access the name of the shape layer in the anchor point property.
    Not sure what is the theory here.
    But is the hierarchy working in this way? :
    *shape
    -3
    -3rd
    -Group1
    -Transform : Group 1
    -Anchor Point
    Ahad Elshabeb replied 5 years, 8 months ago 2 Members · 6 Replies
  • Ahad Elshabeb
    January 13, 2021 at 5:23 pm
  • Filip Vandueren
    January 14, 2021 at 9:14 am
    It is actually going up 6 levels in the hierarchy.
    Every “Group” has an invisible child named “Contents”, everything in the Group is actually a Child of its “Contents” so your hierarchy is:
    1- Shape
    2– Contents (only this top-one is visible in timeline)
    3— Group “3”
    4—- Contents (invisible)
    5—– Group “3rd”
    6—— Contents (invisible)
    7——- Group “Group 1”
    8——– Transform
    9——— Anchor Point
  • Filip Vandueren
    January 14, 2021 at 9:26 am
    BTW, to be clear:
    the Transform and AnchorPoint are NOT inside of “Group 1″‘s Contents, but the Rectangle Path IS inside of Group 1’s Contents.
    Every Group has these subproperties:
    Group:
    – Blend Mode
    – Contents
    – Transform
    – Material Options (Only visible for 3D layers in the Cinema 4D rendermode)
  • Ahad Elshabeb
    January 19, 2021 at 12:05 pm
    Hi Filip… Thanks for your reply. It is not working as intended.
    Would you please clarify how would it be 6 levels up if Transform is not in the hidden group contents. Doesn’t it still go up 4 levels to get to Group”3″‘s name.
    Based on the hierarchy you have done, I want to get from level 9 to level 3, skipping the invisible levels 6 and level 4. By that logic anything in rectangle path will go up the 6 levels.
    Am I getting it ?
    I really appreciate you time on this man. Thanks again.
  • Filip Vandueren
    January 20, 2021 at 9:49 am
    Hi Ahad,
    The Transform Property Group is at the same depth as the hidden Contents group.
    So “anchorPoint” has to count “Transform” as 1 level.
    And “Rectangle Path” would have to count invisible “Contents” as 1 level.
    Hope that’s clear.
    I suggest you use the script “gimmeproppath” to inspect the hierarchy.
    The website redefinedy.com where you can find the script is down, but I think you can still download from here:
    http://web.archive.org/web/20201127123358/http://redefinery.com/ae/rd_scripts/
  • Ahad Elshabeb
    January 21, 2021 at 10:33 pm
    Many thanks Filip.
    I figured it out by trial and error. I had to go up 4 levels I suggested.
    The hierarchy you wrote was absolutely right . Thanks very much man.
