HELP PLEASE about Field Render (upper or lower filds first)???
Upper field first, Lower field first or off field ???
A have a big problem, please help?
maybe I sound like a beginner but:
In my composition I have a video file with Matrox DVCAM compression i think it’s in off fields
when i import this video in AE and make some changes or colour correction I must export the video in
MATROX DV CAM compression with LOWER FIELD FIRST to have nice end smooth video when i import that video in adobe premiere and preview on monitor.(why???)
But if I do some animation in AE then I must set the render settings UPPER FIELDS FIRST(Why ???)
Now I have a problem with one commercial, and I need a solution soon.
in my composition I have a video file(PAL 720X576 – 25 fps) with some animation in After effects,
If I export the composition with Lower fields first then the rendered video will flicker(The video file which is in composition is smooth, but the animation flickers)
Or If I export the video file in Upper Field first then the animation is smooth but the video file flickers.
With off fields, the whole video flickers (when i import that video in adobe premiere and preview on monitor).I work with matrox RTX 100
25 fps, video pal – 720 X 576Please help!!!!!
or give me some material to understand the rendering video betterFrom Macedonia
