Activity › Forums › Adobe After Effects › HELP! phantom keyframes
  • HELP! phantom keyframes
    Posted by M@ on April 29, 2005 at 8:17 am
    I have been having the strangest problem with animation. Objects will move between identical keyframes. Has anyone dealt with this problem? What can I do to avoid it? The keyframes are exact matches and there are no keyframes between them but the objects will move away and then back to the original position between the two keyframes.
    The preceding has been a forum interaction with M@. For more information or to recieve a written transcript simply re-read this thread.
    Andrew Yoole replied 21 years, 5 months ago 4 Members · 3 Replies
  • Mylenium
    April 29, 2005 at 9:34 am
    If it’s Bezier keyframes, the interpolation will do that.
    Mylenium
    [Pour Myl
  • Andrew Kramer
    April 29, 2005 at 11:07 am
    change the default spatial interpolation to linear.
  • Andrew Yoole
    April 29, 2005 at 2:18 pm
    Solution 1: Set first keyframe to a Hold keyframe.
    Solution 2: Select both keyframes, then in Animation/Keyframe Interpolation, make sure all are set to Linear.
    To avoid in the future, set “default spatial intertpretation to linear” on in preferences.
