Activity Forums Apple Motion Help painting a line of light – project is due tomorrow!
  • Help painting a line of light – project is due tomorrow!
    Posted by Stu Siegal on May 24, 2009 at 5:26 pm
    OK, I’ve tried everything but can’t make this work. What I’m trying to do is paint a line using light that wraps around text from back to front.
    The line is wave shaped, paints on, arcs upward behind the text (the word Martial), reaches a peak, then arcs down and should continue it’s path in front of the text. Can’t get it to work.
    I’ve tried putting the line below the text, duplicating it, putting the dupe on top and then bringing the dupe in when I want the wrap to come around front. This does not work, because of the slow rate at which the light paints on, which I don’t want to change. (I know this is hard to explain, but trust me, this method doesn’t work.)
    So then, I tried creating a clone layer of the top line and masking the first half of it, so that it only becomes visible halfway through, but I can’t get the mask to work. What am I missing?
    What other method can I try?
    Thanks.
    http://www.verite-media.com
    Stephen Smith replied 17 years, 3 months ago 2 Members · 5 Replies
