Activity Forums JVC Cameras HELP! On-going problem capturing to FCP from my JVCHD100
  • HELP! On-going problem capturing to FCP from my JVCHD100
    Posted by Pasquale Iannino on October 14, 2009 at 3:21 pm
    I keep having issues when recording from my JVC GY-HD100u in HDV 30p mode.
    While capturing, different parts of the recording are missing because it searched for timecode or something. I miss some sections of the content because of this. It can be during a take where I dont stop recording too! I dont ever rewind my footage so I dont know why its doing this. It’s especially problematic when conducting an interview and I miss some important info. This problem does not happen in SD mode. I can see the footage recorded on tape but it just doesn’t capture. Any Suggestions?
    Mandeep Singh replied 16 years, 8 months ago 4 Members · 5 Replies
  • Phil Balsdon
    October 14, 2009 at 9:22 pm
    You don’t say what version of FCP you are using or what type of Mac.
    If you are using FCP6 try capturing as ProRes. Here’s how https://www.steadi-onfilms.com.au/vlog/?p=61
    If you are using a desktop tower and have second internal SATA drive use that to capture your media, if not and you are using an external firewire drive disconnect any other unnecessary firewire devices.
    Cinematographer, Steadicam Operator, Final Cut Pro Post Production.
  • Peter Brewer
    October 16, 2009 at 9:14 am
    This is a very common problem between FCP and JVC ProHD. The best way to avoid the problem is to capture with DVHSCap and wrap the files with ClipWrap. You can download DVHSCap here… https://mac.softpedia.com/get/Developer-Tools/Apple-FireWire-SDK-X.shtml
    It’s part of the firewiresdk.
    Peter Brewer
    http://www.peterbrewer.net
  • Pasquale Iannino
    October 16, 2009 at 2:51 pm
    Thanks this looks like it will help the situation!
  • Pasquale Iannino
    Perfect! Thank You!
  • Mandeep Singh
    December 14, 2009 at 9:50 pm
    I am facing same issues now twice earlier i acquired through windows install on my mac .i also used PRO-HD RECORDER/PLAYER BR-HD50U but its a brick also . If i import it into premiere pro i do not get any footage option but hell compressed mpg . any ideas?
