Activity Forums Adobe After Effects Help: Objects in 3D space changing position for no reason
  • Help: Objects in 3D space changing position for no reason
    Posted by Eric Goldstein on July 13, 2007 at 9:10 pm
    I’m working on a complex project with many layers (hundreds) – most are 3D layers. I have two different areas of the comp in which a layer far back along the Z axis are moving in space. There are no key frames for movement on these layers. Only the camera is moving. In both situations the the layer jumps in the space of one frame. The only thing similar about the two layers is that they are both the layers furtherest away from camera.
    They are parented layers, the node that controls them has no key frames associated with it.
    Any ideas what might be going on?
    Eric
    Eric Goldstein
    Giraffe Film Company
    Los Angeles
    eric@giraffefilm.com
    Eric Goldstein replied 19 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
