Activity › Forums › Apple Final Cut Pro Legacy › Help! no audio
Help! no audio
Posted by Ann Lukacs on October 22, 2005 at 3:48 pmI opened FCP and I can’t get it to play the associated audio. It worked before. What happened? How do I fix it!? Other applications on the computer play audio.
Kevin Monahan replied 20 years, 11 months ago 3 Members · 3 Replies -
Ben Holmes
October 22, 2005 at 3:55 pmJust happened to be on and posting…
Stop me if I’m stating the obvious, but click on “Final Cut Pro” on the menu bar, then “Audio/Video Settings” then check the setting for “Audio Playback” at the bottom.
If you’ve been using firewire to load/play DV then it may be set to Firewire Audio rather than Built-In Audio. Or vice-versa. I assume that you don’t have a seperate capture card, as your question is not that specific.
If that doesn’t work, post some more details about your problem (video format, other equipment etc.)
Ben
Ann Lukacs
October 22, 2005 at 4:01 pmThat was it! It may be the obvious unless you’re a complete frustrated beginner under deadline. Thanks!
Kevin Monahan
October 24, 2005 at 6:36 pmIt’s a better idea to always monitor audio via FireWire>DV Deck, not through the Mac. Always be mindful of your settings.
Kevin Monahan
Take My FCP Master’s Seminar!
fcpworld.com
