help needed with rotation of tracking area/ cloned area
Ok, let me try this again and I’ll try to be clearer. I used track motion and a single tracking point/ area to follow a feature in a video. I then pick whipped a cloned area back to the feature area of the single tracking point, so the clone would follow the tracked area. Herein lies the problem, however. While I can adjust clone movement of individual frames simply by adjusting the feature center values (since I have the clone pick whipped to the feature center of the track point), I see no way to adjust rotation and I need to be able to do this. In retrospect, it looks like I should have chosen the “rotation” option in the tracker menu and been presented with two tracking points but unfortunately I didn’t do this, so I’ve only been using a single tracking point. The cloned areas I need to rotate are just a few frames and I can do this manually if needbe. I just need to figure out if rotation is somehow possible without having to do a bunch of tracking all over again.
Hope I was clearer and thanks for your help.
Jon
