Help needed Re working with AVI files and outputting
Hello,
This is what I am trying to do. I have a video that was ripped from a commercial DVD and sent to me. I want to put a menu and markers on it and burn it back onto DVD. The AVI file I have is 717KB, 1:46 duration, 576 x 320. If I use something like DVD Santa to burn it to DVD (which renders it to a VOB file first), it looks great when I play it in my DVD player, but no menu/markers. When I put the clip into Premiere, add a menu and the markers and burn it, and then try to play it on my DVD player, the image on my TV is about half size with a lot of jaggies and the audio doesn’t see to sync with the video 100%. For export settings I ues NTSC DV 16:9 High Quality 4Mb VBR 2 Pass Preset setting. The Video Codec that is indicated on the Video tab, which appears to be the only one there, is MainConcept MPEG Video. The Quality slider is set at 5.0. I would appreciate any insight to the problem and suggestions how to cure it. Thank you.
