Activity › Forums › Boris FX Particle Illusion › help needed ASAP
  • help needed ASAP
    Posted by Misticlass on May 8, 2007 at 12:21 pm
    hi
    Im hoping someone can help me, I’m trying to make loopable backgrounds using Particle illusion.. I want to make as many as I can but unsure how to go about making them loopable.
    The first partical im trying to make into a loop is one called…emitters_05_04 Twisted Tower ….if anyone knows how to make this one loopable as well as some of the others maybe has a tutorial that would work with this one an any of the others it would be of great help
    Thank you
    Jane
    Misticlass replied 19 years, 4 months ago 2 Members · 3 Replies
  • Misticlass
    May 8, 2007 at 4:13 pm
    Just thought I would add.. Iv just managed to loop some of the emitters by following a tutorial I found, but still having problems with emitters that are pre loaded like the one im keen on looping called emitters_05_04 Twisted Tower this emitter has preloaded frames of over 200 when I take the pre load away I cant get it to loop as the full emitter effect or it has a jump in the finnished render, can anyone help with how to loop emitters that need the pre loaded frames to get the full effect.
  • Alan Lorence
    May 8, 2007 at 4:19 pm
    Try setting preload to 0, then work with frame 200 as the starting frame.
    Alan.
    http://www.wondertouch.com
  • Misticlass
    May 8, 2007 at 5:11 pm
    I will try that now thank you Alan
