Activity Forums Sony Cameras Help Needed ASAP To Correct An XDCAM Transfer Problem I Created!
  • Help Needed ASAP To Correct An XDCAM Transfer Problem I Created!
    Posted by Colin Richards on April 9, 2008 at 3:05 pm
    I am currently working on a project for a client and I was unable in import a file because FCP kept telling me that I may not have sufficient space.
    I found a post on here and I made an amendment to the “Cache” settings in the XDCAM Transfer menu incorrectly. Now when I try to import XDCAM files, the XDCAM Transfer windows doesn’t come up. The XDCAM Transfer software just hangs. I un-installed / re-installed the SxS software and XDCAM Transfer software and the XDCAM Transfer window still doesn’t come up. I guess I need to just find a way to reverse what I did.
    Help needed ASAP!
    Don Greening replied 17 years, 11 months ago 5 Members · 6 Replies
  • Michael Palmer
    April 9, 2008 at 4:17 pm
    Email me a contact number
    mikepalmer61@gmail.com
    and I’ll give you a call.
    Good Luck
    Michael Palmer
  • Don Greening
    April 9, 2008 at 4:32 pm
    [Colin Richards] ” I un-installed / re-installed the SxS software and XDCAM Transfer software and the XDCAM Transfer window still doesn’t come up.”
    You may have re-installed the Sony Transfer Tool Trying to rectify the problem but unless you also deleted the older Sony Transfer Tool’s preference file the same problem will remain. You can follow the path below to navigate to this file and delete it. Once that’s done you can start the Sony Transfer Tool and it will default to its initial preference settings.
    Macintosh HD>users>yourname>library>preferences>com.sony.bprl.xdcamtransfer.plist
    Drag the .plist file to the trash and restart the Sony Transfer Tool.
    – Don
  • Colin Richards
    April 9, 2008 at 11:33 pm
    Don,
    I can’t thank you enough for your help. Your instructions worked perfectly and everything is up and running again.
    Thanks for your assistance.
    Colin
  • Sverker Hahn
    April 10, 2008 at 6:39 pm
    This was probably a wrong import setting i preferences of XDCAM Tranfer.
    The settings in FCP is not relevant when importing XDCAM EX-files.
    Sverker Hahn, Stockholm
    Slower is better!
    Sony EX1
    Canon XH A1
    iMac Intel
    Final Cut Studio 2
  • Louise Michaels
    September 9, 2008 at 12:16 am
    Can you advise why my Transfer opens with “no image available” in each thumbnail and only info… and no clip plays in the player window either??
    Have a G5PowerPC, 10.4.11 and XDCam EX1
    thank you in advance!
  • Don Greening
    September 10, 2008 at 10:19 am
    You need Final Cut Pro v.6.0.2 to make it all work. The XDCAM EX codecs that allow you to see the picture reside with FCP 6 and not the Sony Transfer app.
    – Don
