Activity › Forums › Apple Final Cut Pro Legacy › HELP my RAID went away all of the sudden!!!!!
  • HELP my RAID went away all of the sudden!!!!!
    Posted by Delano Bryant on November 13, 2007 at 7:19 pm
    My RAID isn’t seen by the system. and I get an error saying disk I inserted needs to be initilized. In Disk utility I have for Raid name a bunch of weird charectors. Does anyone know how to save the info on the DISKS? IT’s a SATA Raid with one internal and one external drives
    Is that the color red you want to use?
    Delano Bryant replied 18 years, 10 months ago 5 Members · 9 Replies
  • 9 Replies
  • Walter Biscardi
    November 13, 2007 at 7:23 pm
    What do you mean one internal / one external drive? You RAIDed to unlike units together? Not recommended.
    I do recommend you purchase and download Disk Warrior to see if it can repair your RAID and then you can copy the material off your array.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    STOP STARING AND START GRADING WITH APPLE COLOR
    The new Color Training DVD now available from the Creative Cow!
    Read my Blog!
  • Delano Bryant
    November 13, 2007 at 7:27 pm
    These two drives are designed for this they come as a set. I will download disk warrior. thanks.
  • Jeff Greenberg
    November 13, 2007 at 7:40 pm
    It’s possibly that one disk is bad – Walter was right – this is a bad setup for a raid.
    If both disks aren’t operating (and operating well) neither will show up. You might want to check to see if Disk utility sees both (or only one.)
    Best,
    Jeff G
    Principal Instructor
    Future Media Concepts
    FMCTraining.com
    Editorsretreat.com
  • Walter Biscardi
    November 13, 2007 at 7:42 pm
    [Hdfilmmaker] “These two drives are designed for this they come as a set. I will download disk warrior. thanks.”
    I’ve never heard of anything like that. Raiding together internal and external drives are definitely not recommended.
    What array is this?
    Read my Blog!
  • Delano Bryant
    November 13, 2007 at 7:43 pm
    Disk Ut and Disk Warrior both see the drives but not together as a raid. One of the drives have a messed up name. and Disk Warrior says they are both working normally.
  • Chris Borjis
    November 13, 2007 at 8:26 pm
    Is it setup as raid zero? (both are combined in a single volume for speed)
    if so, you probably lost everything.
    the single reason I NEVER use raid zero unless I have the contents backed up elsewhere.
    Diskwarrior is a necessary investment though.
  • Delano Bryant
    November 13, 2007 at 8:55 pm
    I think i scared it into working.
  • Arnie Schlissel
    November 13, 2007 at 11:04 pm
    Back it up immediately, then reformat the RAID.
    Arnie
    Now in post: Peristroika, a film by Slava Tsukerman
    https://www.arniepix.com/blog
  • Delano Bryant
    November 13, 2007 at 11:06 pm
    I’ve been transfering for 2 hours. as soon as its done. Bam, reformat!
