Activity › Forums › Adobe Premiere Pro › HELP!!! Mpeg file won’t import into Premiere Pro or After Effects 6.0
  • HELP!!! Mpeg file won’t import into Premiere Pro or After Effects 6.0
    Posted by Jeff Young on January 13, 2007 at 10:48 pm
    Trying to import an mpg file into either Premiere Pro or After Effects 6.0. When I try this it freezes up either program.
    Need to be able to export it to play on a videoboard.
    Any thoughts? I know it’s a rookie question but I desperate.
    Jeff
    Mike Velte replied 19 years, 8 months ago 3 Members · 2 Replies
  • Blast1
    January 13, 2007 at 11:25 pm
    Any version of Ppro except ver 2.x doesn’t like Mpeg2 files, Mpeg1 will work with quicktime 5 or higher installed, likewise with AFX 6.x, AFX 7/Ppro 2 will handle mpeg2 files with QT installed, information on file types for import and export is advailable in the instruction manual that came with your software.
  • Mike Velte
    January 14, 2007 at 12:36 pm
    Premiere Elements 3 can handle Mpeg files much better.
