Activity › Forums › Apple Final Cut Pro Legacy › Help: MPEG-2, 30 bis 50 Mbit/s, I-frame-only 4:2:2P@ML
Posted by Giacomo Snyder on December 2, 2009 at 8:32 pmI have to upload a movie with the following specifications:
Anyone can give me pointers on the correct settings in FCP/Compressor?
Or do I even have to use a different software?Thanks!
GiacomoJeremy Garchow replied 16 years, 9 months ago 4 Members · 6 Replies -
Jeremy Garchow
December 2, 2009 at 9:20 pmI don’t understand what 30 bis is.
The rest looks like a transport stream. Episode Pro should do it for you, but check with Telestream first.
Jeremy
Giacomo Snyder
December 2, 2009 at 9:23 pmIt means 30 to 50Mbit.
So there is no way to deliver this with Compressor? -
Jeremy Garchow
December 2, 2009 at 10:06 pmYou can get up to 40Mb/sec in Compressor.
Just choose a new MPEG-2 preset and choose ‘Generic’ for stream usage.
In the extras tab you can choose 422.
Unfortunately, you can’t choose the GOP structure, so not sure if it’s I-Frame only or not.
Jeremy
Alan Okey
December 3, 2009 at 12:56 amCompressor can’t can’t encode MPEG-2 with 4:2:2 chroma sampling, it doesn’t support it. You’ll need to use Telestream Episode for this functionality.
Greg Booth
December 3, 2009 at 1:51 amHi,
If I’m not mistaken:
422P@ML, MPEG2, I-Frame only, 30/40/50 MBit is also the specifications for Sony IMX NTSC/PAL 30/40/50 MBit – which can be exported out of FCP and Compressor as MOV files.
Hope that helps!
Cheers,
GregCalibrated Software
Jeremy Garchow
December 3, 2009 at 1:18 pmIt does, you just have to turn on the Generic profile. It still doesn’t do as much as Episode, though.
Greg, duh. Yeah D10/IMX it is.
