Activity › Forums › Maxon Cinema 4D › HELP: Modeling of a 6 panel football/soccerball
  • HELP: Modeling of a 6 panel football/soccerball
    Posted by Matthias Heijnsbroek on August 13, 2019 at 2:57 pm
    Hi guys,
    A client of mine asked if I could make a 6 panel ball. Such as this one:
    I need some good advice, or maybe even an already made model. Because I’m really strugling with the curve. If you think of one panel as a hourglass, then the middel (thinnest) part needs to be thinner.
    I tried it using a tweaked Dodeca-Platonic:
    And I tried it using a tweaked Octa-Platonic, but the problem then is that there are straights instead of all curves:
    Hell I even tried making the panels flat, and tried to bend them. But that only made things deform:
    It would be awesome if someone could help me. But I can understand that I might be vague, so feel free to ask for more details.
    Greets,
    Matthias
    Corrado Carlevaro replied 7 years, 1 month ago 3 Members · 3 Replies
  • Frank Feijen
    August 16, 2019 at 12:22 pm
    I’d try to do it with a spline, spherify and some cloners:
  • Matthias Heijnsbroek
    August 19, 2019 at 10:21 am
    Thank you Frank,
    I’ve been tweeking since I’ve posted this question. And got quite a bit right. But at the same time quite a bit wrong.
    The model looks pretty like the real one, but when I start moving some points around in the UV-edit. It bends the texture a lot. (Because the model isn’t 100% accurate)
    I tried your way, and it looks prety good. But as long as I haven’t an accurate model it needs tweeking, tweeking and more tweeking. But there isn’t much budget and they want it to be perfect, so yeah…
    Here you see how much I need to move the corners to align them with their template.
    And if I try to realign the corners of the model, it doesn’t work anymore with the cloner tool.
    Greets,
    Matthias
  • Corrado Carlevaro
    August 20, 2019 at 6:00 pm
    I don’t have the answer but usually this “platonics” are very easy to do when you know how ☺
    I would stick to the dodecahedron, get rid of the edges cutting the pentagons, subdivide once and using two penthagons for each panel. Then (maybe using “snap to spline” as a guide) sliding the points to round the “convex” and “concave” edges of the pentagon pairs, subdivide and spherify. This way you should also get a smoother and regular mesh/UV
