Activity Forums Media 100 Help – Media 100 crashing after SATA II Two Big drive installed
  • Help – Media 100 crashing after SATA II Two Big drive installed
    Posted by Tom Gillen on April 8, 2006 at 12:06 am
    I installed a LaCie Two Big Drive with a card and had to upgrade my Mac OS to 10.3.9 and Quicktime to the latest version and now Media 100 crashes everytime I place a graphic on the time line and want to edit it. It also crashes when I put in a transition and start to render it. The whole screen goes gray and I have to reboot the whole computer. The SATA drive seems to be working ok and it plays back footage I’ve digitized. Any Ideas? I have a dual 800 G4. And REAL Time EFX board. Thanks in advance.
    Tom Gillen replied 20 years, 5 months ago 2 Members · 4 Replies
  • Tom Gillen
    April 8, 2006 at 12:11 am
    Also, I noticed in AE on the same computer I was able to render to Animation but when I tried to render to the Media100 codec it crashed in a similar way. Must be something going on with the Media100 codec?? I think the problem is more with the upgrade of the OS rather than the SATA drive. Any thoughts?
  • Jim Calahan
    April 8, 2006 at 3:42 am
    Are you editing in HD? The drive may not be fast enough, you would need something raided for HD.
  • Tom Gillen
    April 8, 2006 at 4:38 am
    No HD. I’m still using Media 100i 8.2. The speed is very fast. The crashes are happening whenever I have to render a clip or transition….My Quicktime version is still 6.4. So it’s not the QT 7 problem either. Still no luck figuring it out. Any other ideas?
  • Tom Gillen
    April 8, 2006 at 5:45 am
    Jim,
    I upgraded to Media 100 Vers 8.2.1 and voila, everything works again!! Yea! Thanks for your concern.
