Activity Forums Adobe After Effects Help! MainConcept Encoder producing garbage in 6.5
  • Help! MainConcept Encoder producing garbage in 6.5
    Posted by Markp on June 26, 2006 at 6:43 pm
    Hi folks.
    The MainConcept MPG encoder that shipped with AE 6.5 has been an important part of my work-flow for some time.
    Unfortunately for some reason, the MainConcept export option has started producing corrupt .m2vs – no matter what settings I’ve tried. The effect is stuttering, freezing, and pixelated garbage across the bottom half of the image.
    I’ve uninstalled and re-installed AE to no avail. I noticed a similar problem a couple of months back on another machine.
    Has anyone else experienced this problem, and is there a repair?
    All suggestions much appreciated.
    ( I’m stuck with AE 6.5.1 as AE 7.0 refuses to install on AMD processor-based machines. For which thanks, Adobe…)
    Markp replied 20 years, 2 months ago 1 Member · 0 Replies
  • 0 Replies
