Activity › Forums › Adobe Premiere Pro › Help! I messed up my audio recording
  • Help! I messed up my audio recording
    Posted by Moval Rob on April 13, 2007 at 5:09 pm
    So I made a huge mistake, I produce a small talk show and there is no audio on the master tape I recorded to. I did record iso tapes in the three cameras I had on set, however, these only have audio from the on camera mics. To the question, is there a way(filter, other software etc.) that I can clean up the audio from the on board cameras to sound like the lavalier mics? Any help is really appricaited.
    Vince Becquiot replied 19 years, 5 months ago 2 Members · 1 Reply
  • Vince Becquiot
    April 13, 2007 at 6:19 pm
    You can try to add some gain and clean up background noise with audition, but there isn’t much improvement that can be made really.
    Even a gate may improve things a little, but the end result will likely remain close to the original with the amount of work you will be putting in it.
    We all learn quickly with those kind of mistakes 🙁
    Vince
