Activity Forums VEGAS Pro help! I can’t import an mpeg1 file … everything else works just fine
  • help! I can’t import an mpeg1 file … everything else works just fine
    Posted by Mbuckingham on November 21, 2006 at 4:24 pm
    Ugh…I have an mpeg1 file that I need to bring into my timeline but it says it’s not supported.
    Can I do this or is there something I need to do beforehand?
    Help!
    Actxiom101 replied 19 years, 10 months ago 3 Members · 5 Replies
  • Edward Troxel
    November 21, 2006 at 10:24 pm
    MPEG1 should import just fine.
    Edward Troxel
    JETDV Scripts
  • Mbuckingham
    November 22, 2006 at 2:18 am
    That’s what I thought. I’m running Vegas 4 if that makes any difference…with the most current update.
    I get an error that says the format is not supported. I’ve tried to drag and drop like I normally do as well as importing it…
    It’s from a stock library, so maybe I’ll just try downloading it again.
  • Actxiom101
    November 22, 2006 at 4:39 am
    Are you importing an mpeg1 file that has been rendered, compressed. So are you dropping this onto a Vegas editing timeline? Then are you going to create a DVD?
    Am afraid I am confused. But lately that is quite normal.
  • Mbuckingham
    November 22, 2006 at 4:46 am
    It is already rendered, it’s a loop clip from BarnaFilms. I’m trying to drop it in the timeline but it won’t let me. I’m actually just going to create a new mpeg, the clip is just a part of it.
  • Actxiom101
    November 22, 2006 at 9:45 am
    OK, gotcha. Way beyond my expertise.
