Activity Forums Adobe Photoshop Help! How do I use an alpha channel to get the transparency from a photoshop image??
  • Help! How do I use an alpha channel to get the transparency from a photoshop image??
    Posted by Bill Russell on February 25, 2006 at 12:41 am
    Hi, I have a photoshop image — a feathered title against black. Instead of a transparency it has an alpha channel. How do I use the alpha channel to get the title with transparency? If I ctrl-click the alpha channel to get a selection, then copy-and-paste from the title, the black background gets mixed in with the selection. I know there is a way to do this, but I haven’t a clue how. Help! Thank you!!!
    “THE LOST SKELETON OF CADAVRA”
    And more…
    Chris Wiseman replied 20 years, 6 months ago 4 Members · 3 Replies
  • Jeff Memmer
    February 25, 2006 at 7:04 am
    Do this (u can probably skip straight to the alpha channel step since you said one already exist, but just in case, I left all the steps in there — and you don’t have to make the mask at the end) The video link is at the bottom of the post:
    EXTRACTION
  • Jim Kanter
    February 25, 2006 at 5:08 pm
    1. Duplicate the layer and turn off the bottom (original) layer.
    2. Select the top layer (the copy).
    3. Selection > Load Selection and choose the Alpha Channel.
    4. Invert the selection.
    5. Delete.
    Jim Kanter,
    Digital Film Institute
    http://www.dfilminst.com
  • Chris Wiseman
    March 10, 2006 at 2:34 pm
    NT
