Activity › Forums › Apple Final Cut Pro Legacy › Help! HDV-FCP 5.02 capture settings
Posted by Faryar Mansuri on October 23, 2005 at 7:22 pmLadies and Gents:
trying to capture HDV from Sony Z1 (for the first time)
upon capture , the sequence displays only a still image.
what are the correct playback settingshelp is appreciated
thanks
faryarFCP 5.02
G4 powerbook 1.67
1 gig RAM
128mb display
lacie 7200RPM firewire 800 trnsfer.Steve Connor replied 20 years, 11 months ago 3 Members · 8 Replies -
David Roth weiss
October 23, 2005 at 8:22 pmFaryar,
Unless you captured as SD from the Z1 camera you have no way of viewing HD on your laptop. On my G5 I have a BM Extreme card that allows me to display HD on a SD monitor and output to a SD deck. With a laptop I’m not sure that is an option.
DRW
Faryar Mansuri
October 23, 2005 at 8:36 pmI managed to be able to capture and playback the HDV footage in the source viwer as well the sequence.
I really think its the settings…dont ask me which, i just craeted a new project and it worked.before upgrtading to 5.0 i could play full screen in second attached vga monitor; now when moniror is attached the image freezes, audio however is heard.
any ideas?
thanks
faryar -
David Roth weiss
October 23, 2005 at 8:59 pmOf course, I wasn’t thinking… I was playing poker online when I answered your question.
Faryar Mansuri
October 23, 2005 at 9:20 pmDavid,
another poker question for you…
I am trying to capture in HDV and output to DVDSP to create a 5 minute SD DVD?
what is the workflow…do you export a QT off the TL or export a mpeg 2 using the compressor presets?and what if one was to make a QT file from an HDV file to show cleint on the computer PC or Mac
thanks
faryar -
David Roth weiss
October 23, 2005 at 9:27 pmBoth will work just fine. Compressor presets will work just fine. I’ve read lots about people having probalems, but it works for me.
Sorry I made the stupid befre, but I’m playing poker for millions of dollars.
In play money…
Steve Connor
October 23, 2005 at 10:15 pmThere is an issue with Compressor and HDV sequences, where the field order is reversed.
https://docs.info.apple.com/article.html?artnum=302073
Easily fixed!
Steve Connor
Cardinal HDPlease fill in your profile – it helps US to help YOU!
Steve Connor
October 24, 2005 at 8:59 amEnd of last week I think.
Steve Connor
