Activity › Forums › Apple Final Cut Pro Legacy › Help – General Error
  • Help – General Error
    Posted by Paul Rijkaard on October 17, 2007 at 7:39 pm
    My Colleague is currently working through a time pressured edit and is experiencing an unusual General Error in FCP 4
    A reliable system – Power Book G4, but using a brand new G-Tech Hard drive 250G 7200 Firewire.
    Footage captured fine (DV Pal) but working in the timeline he tried to retime a clip – a standard procedure
    and Final cut closed the timeline and viewer, posting a message – General Error – Out of Memory
    The project will now not open in FCP although other old projects on old hard drives work fine.
    He has moved the footage from the new hard drive to an older reliable drive – but 1 file (60 mins in length) reads error bad file cannot copy.
    However this file plays fine (from the new hard drive) in QT and FCP.
    The power book has 1.5 Gb RAM and 15 GB free on the hard drive
    the system settings use the new hard drive as capture, waveform and render
    is there any help out there??
    Adam Taylor replied 18 years, 11 months ago 2 Members · 1 Reply
  • Adam Taylor
    October 18, 2007 at 10:44 am
    you might be able to open up a version from the autosave vault. This seems about the only way i have found to retrieve a sequence after this happens.
    I have had this problem many times and once it happens there does not seem to be any way to rescue the sequence.
    No one has – to my knowledge – been able to say what is causing this problem. Its certainly not uncommon though!
    adam
    Editor/Mixer
    Character Options Ltd
    Oldham, UK
