Activity Forums Adobe Premiere Pro HELP! Frame size issues??
  • HELP! Frame size issues??
    Posted by Kalufsen Jansson on March 21, 2008 at 12:54 am
    Hi!
    I am using Premier Pro 1.5 and putting together a movie about 3:40 min long, mostly flash animation and adding some video clips and a voice track. The problem is that the frame size is set up to 854x480px the very same size as the exported flash-to-quicktime movie clips. But as I put the flash clips in, they don’t have the same size ratio as the premier stage. The premier stage seem to be wider???
    Second question is I am exporting it as quicktime, which makes it 3.3GB then I compress it in Sorenson Squeeze HD 480p and it becomes around 60MB but the quality still isn’t that great… Any ideas???
    Thank you so much for your time!!!!
    Vince Becquiot replied 18 years, 5 months ago 3 Members · 2 Replies
  • Randy Mcwilson
    March 21, 2008 at 6:57 am
    The first issue is most likely related to your pixel shape, either square or non-square pixels. Right click on your clips in the project window and go to interpret footage. Look at the pixel settings, and make adjustments.
    The second question is a bit harder to pinpoint. You just have to look at your individual parameters in the export module and tweak.
    Render out shorter (like :10sec) clips until you find an acceptable setting.
    Randy
    Eternity…don’t miss it for the world.
  • Vince Becquiot
    March 21, 2008 at 4:11 pm
    As far as quality goes, many people tend to compare their H.264 footage to that of an Apple trailer, which really was encoded from 4K footage in most cases, and often with much less grain and noise than any camera under $80,0000.
    Try posting a still if you can.
    Vince
