Activity › Forums › Apple Final Cut Pro Legacy › HELP! FRAME RATE DESCREPENCY WHEN ONLINING HDV
Posted by Aaron Wallace on April 11, 2007 at 7:50 pmI posted this issue a week or so ago and have changed the post to be more specific since none of the replies helped.
I’m having a problem when onlining my HDV footage (shot with a HD100) in FCP 5.1.4. I edited using the standard def DV codec at 24p. I create an offline project and then select my clips. I then go to
Aaron Wallace replied 19 years, 5 months ago 4 Members · 7 Replies -
Mark Maness
April 11, 2007 at 8:31 pmWhat Easy Setup you are using?
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com -
Aaron Wallace
April 11, 2007 at 9:27 pmIs Easy Setup the same as Sequence Settings? It looks like my original Easy Setup was DV/DVCPRO NTSC 24p for my DV edit and once I made the offline I set it up in Media Manager to be HDV 720p24p
David Roth weiss
April 11, 2007 at 10:16 pm[awall11] “Is Easy Setup the same as Sequence Settings?”
This is not meant to be a put down, but seriously, on one hand you’re trying to accomplish one of the most sophisticated media management and framerate conversions possible in FCP, and now you’re suggesting that you don’t know the very basics of FCP. That’s pretty scary…
Aaron Wallace
April 11, 2007 at 11:09 pmIf I knew everything about FCP I wouldn’t need the help. Sometimes it helps to backtrack over even the most remedial settings, it appears that Easy Setup is a default setting for Sequences when you open a new project. If that’s the case, then I am doing everything correct and I am still ending up with a Frame Rate problem. If anyone out there knows what I am talking about please point me in the right direction or to an old posts that have covered this….otherwise I am all ears
Gary Adcock
April 12, 2007 at 1:14 am[awall11] ” I get a HDV 720p m2v file but at 30 fps (not 29.97 or 24p). Am I doing something wrong or missing a step? “
OK
what is telling you this frame rate? FCP or QT? (QT is not accurate)
you left out how you how / why/ method for making your HDV content take up more space by editing in SD?
the methodology of your working process needs to be outlined better.
gary adcock
Studio37
HD & Film Consultation
Post and Production Workflows -
Aaron Wallace
April 12, 2007 at 3:14 amLet me start from the top:
https://www.lumierehd.com/forums/showthread.php?t=577
The footage was shot on a JVC HD100 and brought in using Lumiere HD (this was before FCP supported native HDV). The plan was to do the offline in DV and then reconnect to the original HDV files for the online. My editor and I have since learned that we should have used the AIC codec for the offline to begin with but had already began this course. This is my first time dealing with an online, so if the workflow from the Lumiere site is flawed; perhaps another workflow all together will better suit me and I am definitely willing to try something else.
Aaron Wallace
April 12, 2007 at 3:18 amSorry
By the way I see the frame rate in my Browser in FCP and also when I CTRL click the clip and go to item properties it also states the frame rate as 30 fps.
And yeah you’re right about Quicktime….that’s where I am seeing that the clip is at 24 fps.
Thanks everybody for all your advice and questions.
