Activity Forums Apple Final Cut Pro Legacy Help Exporting with this settings in Final Cut
  • Help Exporting with this settings in Final Cut
    Posted by Rodrigo Sanchez vial on June 20, 2009 at 2:40 am
    Need Help exporting a project with this settings:
    Video: QTime.
    Codec: DVCPRO50.
    Standard: NTSC.
    Resolution: 720×480.
    Frame rate: 29.97fps
    Data Rate: 7.5 MB/s.
    Aspect: NTSC / CCIR 601.
    Audio: 4 channel
    Uncompressed.
    Sample Rate: 48 kHz.
    24 bit Integer.
    Embedded in .mov file.
    Anyone knows how please?
    Rafael Amador replied 17 years, 3 months ago 4 Members · 4 Replies
  • Andy Mees
    June 20, 2009 at 3:34 am
    File menu > Export > Quicktime Movie w/ Current Settings and Make Movie Self Contained
    Failing that you need to better explain what you are trying to do Robert. Are the setting listed your target format or your source format or both. If not both, what are your source/target settings?
    Cheers
    Andy
  • David Block
    June 20, 2009 at 9:44 am
    no problem at all, I even think it’s a format template that comes within FCP. So what you need to is selecting in export option.
    Cheers,
    David
    David Block
    Film direction, film edition, compositing, technical trainings
    Sony Vegas Pro Certified Editor
    Certified Pro Final Cut Pro 6, Lvl1
  • Rodrigo Sanchez vial
    June 20, 2009 at 1:48 pm
    Thanks for your help Andy,
    My source is
    Video: QTime.
    Codec: DVCPRO50.
    Standard: NTSC.
    I managed to export all of the settings except the Data Rate? If I modify the Data Rate, I have to modify the codec DVCPRO 50 or the 4 Audio Channels.
    How do I export with 7.5MB/s without modifying DVCPRO50?
  • Rafael Amador
    June 20, 2009 at 3:48 pm
    Hi Rodrigo,
    You can not modify the data-rate of the video channel. Is the standard of the codec.
    About the Audio, if they are asking “Uncompress” (PCM), there is also nothing you can do,
    and every extra Audio channel will increase the data rate.
    Rafael
    http://www.nagavideo.com
