Activity Forums Adobe Premiere Pro Help – exporting to DVD
  • Help – exporting to DVD
    Posted by Rockin Rabbit media on January 19, 2007 at 12:55 am
    I’m helping out a friend by taping and capturing her dad’s memorial service.
    -runtime: 1:47:00
    I’m trying to burn it to DVD in Pro2.
    Using HP writables 4.7g/2hours
    1st. attempt: right from project file to DVD burner
    Result: ‘insufficient disk space for burning’
    2nd attempt: m2v file to burner
    3rd attempt: 3.5g mpeg file to burner
    4th attempt: ISO file to 100gb free firewire drive
    anyone know what i’m doing wrong?
    thanks,
    dave
    Rockin Rabbit media replied 19 years, 8 months ago 5 Members · 9 Replies
  • 9 Replies
  • Vince Becquiot
    January 19, 2007 at 1:13 am
    I think that may be coming from your hardrive itself.. Do you have sufficient space on the harddrive to save the temp files or ISO ? Is the external drive FAT 32 or NTSF ?
    Vince
  • Aanarav Sareen
    January 19, 2007 at 7:12 am
    How much space do you have on your C drive?
    Aanarav Sareen
    premiere@asvideoproductions.com
    https://www.asvideoproductions.com/techtalk
  • Mike Velte
    January 19, 2007 at 12:26 pm
    Maybe you bitrate is too high for a 4.3 GB DVD disc.
    https://www.video2stream.com
  • Rockin Rabbit media
    January 19, 2007 at 12:28 pm
    hmmmm….you may be on to something there.
    i’m sure a temporary file needs to be created huh?
    8.2g free on C.
    …though i believe i set all my scratch disk stuff to point to other drives.
    checking….
    yes
    media cache is pointing to a volume with 14gb free
    scratch disks, video and audio preview are looking to other drives which have between 30 and 52gb free.
    January 19, 2007 at 12:32 pm
    using CBR of 7.0MBps
    changed to VBR min 2, targ 6, max 8…same dilly
  • Harm Millaard
    January 19, 2007 at 2:47 pm
    With 2-pass VBR for a 107 minute timeline NTSC with PCM sound, your average rate should not exceed 4 MB. Use a bitrate calculator.
  • Mike Velte
    January 19, 2007 at 3:03 pm
    Your missing the boat! Your encoding bitrate is too high…for 2 pass VBR you will need a target or average of 3.7 mbps using Premiere and PCM audio.
    6 or 7 mbps wont fit on a single layer DVD.
    I have a bitrate calculator on my web.
    http://www.video2stream.com
    January 19, 2007 at 3:51 pm
    Ok, I’ll give that a shot.
    Thank you VERY VERY much for the info and the link!!
    January 19, 2007 at 11:07 pm
    By GEORGE, I THINK YOU’VE GOT IT!!
    i’m a stills dude, this video stuff is new to me
    Thank you very much fine sir!!!
