Activity › Forums › Adobe Premiere Pro › help creating QT movieClips
  • help creating QT movieClips
    Posted by Navarone on December 27, 2006 at 2:26 pm
    I was left with an Adobe Premiere project which has 15 sections in it that I need to create individual QT movieClips. I think this is what they call a trimmed project. I think I need to use the Project Manager but I am a little unclear as to how to proceed and what settings to use. I would appreciate any help in this matter.
    What is man that you should be mindful of him?
    Mike Velte replied 19 years, 9 months ago 2 Members · 3 Replies
  • Mike Velte
    December 27, 2006 at 8:44 pm
    The Project Manager is needed only if you need to free up disc space. Use the default settings.
    Not sure what you mean by 15 sections?? One timeline or 15 timelines? If one timeline, use the Work Area bar to define the first section and in your export settings, select Work Area as the “Range”. Most QT export codecs are poor, except for H264 which requires QT player 7.x to view.
  • Navarone
    December 28, 2006 at 12:39 pm
    Thanks for the reply. I have one time line whihc is about 22min length. There are 15 areas (sections) that I need to seperate out and then import into AE. I assume that I want QT movies to import into AE, here again this may not be want I need to do. Maybe I can do what I want in AE, I don’t for sure. As you can see I am really green. I know the one time line needs to be broken down into the 15 sections taken into AE where I resize the video and ultimatley I turn those into Flash video, using the Sorenson Squeeze 4.
  • Mike Velte
    December 28, 2006 at 1:50 pm
    You dont need AE to resize or export as Flash (.flv), Premiere can do both. Squeeze is only needed if you need a player skin. Otherwise take the .flv file into Flash for authoring a web page.
